Before you screw anything up, you need to do this: Take off air filter, filter box, side plastics, gas tank. Turn it to the side on way or another to get throttle cable off, two allen bolts that hold the cover on. Disconnect the 2 electrical connectors, twist it so you can get out the side where your left leg goes. Drain into a drip pan, fuel will go everywhere when you tilt it. 17mm bolt on the bottom, take that off. There are 2 jets you can now see. Use a flat head to take the one out, that is your Pilot Jet. Use a 6mm socket for the other, that's your main jet. Write the numbers and or logo's down. The Pilot will be a smaller number.
Next take off the top lid, same size allen head as the side. There is philips head screw that you need to take off, do that without stripping it. Carefully pull the whole slide out. On the top of that slide, there's another allen head. Take out the needle and write down the position the little clip is on the notches, from the top down. There should be some letters on the needle too, write them down.
Stuff a CLEAN rag in the intake of your head, check your plug while the rest of the quad is apart. You can also try to crank it with the plug out. It should spins quite easily. If not, your battery and connections need help or replacing. Inside the starter switch can be pulled apart, cleaned, and lubed with contact grease too.
Post your jetting sizes and needle sizes. Carefully clean your carburator while its out, don't use solvent on that black piece as it can destroy it. This sounds like a pain, but if you take your time you will save some bucks and learn how to do this.
