I want to check my valves and adjust if needed. Is there a kit you can buy or do you buy the pads individually? And where is the best place to buy? Dealer or someone on website? Any tricks I should know about? Is it recommended to use the Molybdemium solfide oil for the cams? Also, can you do it when it is 50 degrees out? Just wondering because the manual says room temp?
Thanks
Thanks
