I removed the nut and washer from the top of the ball-joint which holds the lower front arm to the steering knuckle along with everything the lower arm is connected to. But the ball-joint isn't sliding out of the steering knuckle. Any idea's on how to get that to slide on out? I've hit the top of the ball-joint with a hammer (I'm replacing it anyways) and tried standing on the lower arm but nothing has worked.
Here is a diagram that may help you guys out, and I can take a picture if you'd like:
