A-arm Question
641 views 3 replies 2 participants last post by  jdthomas24
#1 ·
Just installed a set of houser standard travel +1/2" a-arms just wondering if anyone has had a problem with the wheels hitting on the lower arms. It doesnt hit much but it does barely rub. Anyone else with this prob?
#2 ·
what offset are you running? both wheels touch?
#4 ·
running stock offset, but will be going to a 4+1, so i know both with hit when i do that. Right now its just the right side
check th toe to be the same on both, if you have stick which is 3-2 offeset and go with 4-2 offset it will hit more. i had a raptor that hit on one wheel, it turned out to be a stem and steeering link issue, flag mount had a bend in it, slightly.if you are running alot of negative or positive toe it could cause a issue also.
