06 yfz450 wont start
1 reading
1.7K views 5 replies 3 participants last post by  jamie_450
#1 ·
was riding my new quad today and it stalled out like it lost spark or gas and wont start back up. pulled the plug was kinda fouled so i replaced it. i have confirmed it has spark and i can smell gas in the pipe so i don't know why it wont start any ideas??
#3 ·
Could be the tors switch. Does it die when you push the throttle? If so there is a wire that goes into the thumb throttle. In the throttle there is a small switch. If it gets stuck the quad will die when you hit the throttle.
#5 ·
Make sure your fuel feed is set to either "reserve" or "on" lol I did that my very first ride on mine, left it set to off after transporting it and boy did I ever feel dumb XD. If you have it set to "on" there may be gas in the tank, but it may be too low. Are you using the choke to start it? How far out is the choke? Is your air filter clean? Start with the easiest and cheapest fixes and move to the more complicated things like TORS after you have ruled all of those out.
