Zip Tie Mod
4215 Views 10 Replies 9 Participants Last post by  skitchin1
Can someone explain how to do it preferibly with pictures or refer me to a site that shows it?
i understand what its for but i want to know how to do it?
1 - 11 of 11 Posts
search around here the link for the pictures and how-to-do are in several threads on this site
http://yfz450.theatvchannel.com/invision/i...showtopic=86402 heres a pretty good tut. but if your set on the ziptie mod instead of bending the spring, just put the ziptie in and be done with it.
do some years not have the rubber o ring? i went into mine and there was no ring and when i put the zip tie on it seemed to run worse....then i fooled around with it for a bit and got it to work pretty good. the one thing im worried about is the zip tie popping off the linkage but as long as its tight it shouldnt be a problem.
That o-ring was put in there by someone, it was used instead of a zip tie or safety wire. The zip ties/wire will hold it tighter and not stretch like the o-ring probably did. If you are worried about the tie breaking try using some wire.
thanks guys
there are a few videos on youtube that show how to do the zip tie mod... just look it up... its pretty easy
YFZ450 zip tie mod - YouTube
1 - 11 of 11 Posts
