1 - 11 of 11 Posts
Last night was riding. Hit a bump kinda fast & shook the bike kinda hard. It started bogging out & died. Won't fire up. It'll start for a sec & big out. This the second time it's done this. The first time was a while back. Was riding through the trails slow sliding around & hit a stump & put the quad on its side. Picked it up & was bogging out bad but managed to get it home. Wasn't far. Next day turned it on & fired up like nothing & ride perfectly fine till today. Please help
Discussion Starter · #2 ·
Checked timing all good. Checked valve clearance & good. Put a new spark plug. I can get it to idle. I give it gas & it either dies or revs up but bogging bad
What's the battery voltage look like?
It was dead after trying so hard but I'd get cables to jump it
Charge that completely. All FI Yamaha's don't fire the injector(s) unless they have I think 10.5VDC. It's slipping my mind at the moment for some reason, but they require a lot of juice to even fire.
My sensor had mud in it and was stuck tilted. I took the shell off and cleaned that bastard and filled it with silicone.
Another thought... I have also had my valves become so tight once that the bike wouldn't start.
Discussion Starter · #10 ·
I disconnected the battery & took apart the sensor & glued it. Than put it back together & it took a second but fired right up. Working good now
1 - 11 of 11 Posts
