YFZ450R transmission rebuild
304 Views 4 Replies 3 Participants Last post by  phillybuilt
I'm working on a 2016 that exploded a clutch plate and a piece of said clutch plate ended up in the transmission and broke a tooth off of 2nd gear. Has anyone rebuilt one of these before? Usually these transmissions come apart quite easily, gears either slide right off or are merely held by clips. This one gear on the input shaft seems like it's pressed on, and I've never seen that before with dirtbike or atv transmissions. Just making sure before I ruin a friend's input shaft and create more headaches.
Someone please give me some peace of mind before I put this in my press and hurt something else in the process. It's number 8 on the diagram. Thank you.
Automotive lighting Motor vehicle Font Line Automotive tire
Gear Automotive tire Bicycle part Rim Engineering
Sent from my SM-G973U using Tapatalk
When messing with mine a few months back I do remember one or a couple gears that stayed out and didn’t come off.. not sure if your suppose to take apart or not tho
I have the maintenance manual if you need it I can send it to you at your email just message me
It’s for a 22 but I’m pretty sure it’s that same
Ended up repairing it, 2nd gear does need to be pressed off. My 20 ton struggled with it too.
