1 - 13 of 13 Posts
I have stock yfz450r 2014
what is the loudest full exhaust I can get. Also can I fit whatever exhaust it self without any other mods? Like chip or filter
Get the shortest non spark arrested muffler exhaust u can find. Mofo gonna be LOUD.
YES YOU NEED TO ADD FUEL SOMEHOW.
Discussion Starter #5
thanks guys for your support
what is shorty? Does it mean the muffler shorter than normal?
and what is your recommendations for Dosa as I saw shorty on their selection also exhaust type I found classic and 99db which is better and louder ?
Discussion Starter #10
How much is the difference with these mods? Very noticeable?
also I want to get the easiest fuel controller installation easy plug and play with no laptop coding..What is your recommendation?
Vortex is the cleanest easiest install. No wires everywhere install. It is better if you also get a different vortex mount than the weak rubber mount it comes with. Make sure to research what your lo mid hi trims should be at based on mods and elevation.
Discussion Starter #12
Is It Okay To get Dasa alone for now then after month or so I get the fuel controller?
I wouldn't man I would get the vortex first listen to these guys. If u want it to sound louder til u get ur exhaust take the baffle out of the stock pipe AFTER u get the vortex
1 - 13 of 13 Posts
