Here is an almost complete list of all the 1 1/8 bar options that are commonly used. Its not all of them but it may be helpful to anyone looking to go with a similar or taller than stock bar.
"Bar Brand & Name"............."Width"..........................."Height"............"Sweep/Pull"....
Stock Handle Bar...............773mm (30.40")..........110mm (4.43")..........97mm (3.81")
Tusk Chub ATV High...........800mm (31.50")..........120mm (4.75")..........61mm (2.41")
Protaper Adventure............803mm (31.65")..........122mm (4.84")..........81mm (3.19")
Protaper ATV High..............800mm (31.50")..........120mm (4.75")..........55mm (2.17")
Protaper Raptor.................812mm (32.00")..........142mm (5.62")..........86mm (3.40")
Renthal RC High Bend........801mm (31.57")..........114mm (4.49")..........54mm (2.13")
Renthal CR High Bend........794mm (31.29")..........094mm (3.74")..........61mm (2.44")
Fasst 12° Quad Racer Low..787mm (30.98")..........092mm (3.62")..........54mm (2.12")
Fasst 12° Quad Racer.........787mm (30.98")..........115mm (4.52")..........54mm (2.12")
Fasst 14° Quad Racer Low..787mm (30.98")..........092mm (3.62")..........57mm (2.24")
Fasst 14° Quad Racer.........787mm (30.98")..........116mm (4.56")..........57mm (2.24")
I like the stock pull too. The bad part is each bar must have different measuring methods because a few of the bars are almost exactly the same when you put them side by side. If i wanted a close to stock replacement that wasn't stock but appears real close in person.... I would get the the RC high Bend. They look almost the same with a tiny bit more height even though they claim less pull. I'm still on the fence of what bars I'm gonna get but I do want taller.
So is the "pull" the measurement from front to back if it were on the quad?
