so i have a 2013 yfz450r and i run a 15/38 sprocket but i'm changing them to 15/36 i need more top end speed because usually i ride long stretched places and most of the time i do roll racing in second gear so what do you think of the combo ? and will it effect the ride quality? or i will shift less ? also i have the stock length chain do i need to change it ?
Mods are: dasa full exhaust system , k&n air filter, PC5
Rear Tire size: 20*10-9 itp holeshot GNCC
You will lose low end but have top end I ran this set up when I raced flat track on a 1/4 mile circle track. You will get longer space between shifting and I believe the stock length worked I can’t remember that for sure. What kind of riding are you doing?
mostly open and long places such as dunes
If your riding in dunes a lot then 15/36 probably isn’t going to help. You are pretty much capped on speed with your mods. Especially riding in dunes. No do not try to alter the chain length. Bad idea that could get you hurt. Swapping chains won’t net you anymore top speed.
Discussion Starter #5
Its not dunes I don’t know how to describe it to you. An open desert that’s so long distance like 125 miles only desert I am from Middle East so yeah
No i just asking if i should change the chain length thats it
With the smaller rear sprocket you might need to shorten it a bit but your best bet is to get the sprockets on and then measure with the chain on.
Get 21 inch rear tires !!! More clearance and more speed. THEY DO Make them.
