2007 yfz450. i was riding it today and it shut off when i was driving and it wouldnt crank over when i hit the start button, it was making a clicking noise, and sounded a little bit like it wanted to go more. i jacked up the back put it in first gear and i couldnt get the back tires to move more then 2 inches. please help.
If you put it in 1st gear or any other gear the wheels won't turn very easy. What you need to do it take the plug out of the stater cover and see if the motor will turn over out of gear. If the bike is out of gear and the engine won't turn you may have a serious engine problem. Once you have the plug out use a 17mm socket to turn the motor over. If the motor does turn over, you probably have an electrical problem.
