first of all i apologize if this is posted in the wrong spot just joined the forum.
Hey y’all, i just picked up a 2008yfz450, cheap didn’t run great and smoked so i tore it apart cleaned carb and did valve seals, anyway i put it back together, put it in time, (can mod done) and the thing will not start. it will just crank and crank and never hit, not even off starting fluid. i’ve had it apart probably 6 times checking timing and make sure i did it all correct and i’m at my wits end with it.
only problem i can see is the bearing retaining clips with the cap installed i can’t hardly turn the cams by hand i’m not sure if something is pinched, i don’t think so they slide on easy, and i can turn it over with a socket but i would think the engine would still fire right? all i get is an occasional backfire.
(also yes it’s getting great spark, fuel air and compression as it ran before i took it apart)
