2008 yfz450 se, was riding in 5 gear low rpm’s on a dirt road and bogged out and shut off and wouldn’t start again, few days later starts fine most of the time and idles fine, when given the slightest bit of gas it dies, changed the spark plug and still runs the same as before, any suggestions as to what could be happening?? Help pls
Check the throttle safety switch on the right handle bar where you thumber goes into. Not uncommon for the switch to cut the the bike off when the throttle is engaged and it thinks your going wot and it really just that switch I'm there. Has 2 wire going into it on the thumb throttle.
