1 - 13 of 13 Posts
well while i was putting my yfz back together today,i thought about somthing, i wonder if the wiring harness will work off a yz450 it sure dosnt have as many connections that arnt being used, i understand the bike dosnt have elec. start. but if u run kick only will it work? has anyone tried it yet?? maybe the wr450 will work with elec. start????
Hey yogi! Come out of that cave!
You can tear the stock harness to shreds and modify the hell out of it and save yerself tons-o-dough. About the only thing I'd want from the YZ450F would be the same rev limit. Other than that, my "new' harness is very simplified.
I emailed a diagram to the boss here, but haven't been given a link to it to post for ya'll. Oh well, you've probably all seen it elsewhere.
Discussion Starter #4
well i guess i could do that , i just wondered if it would work, my 250r harness was only like 4 short wires, doubtful i can get this one down to that but i will try.
Check your email Asher.
Yeah, me too selector...and how do u swap rev limiters. Whats the difference in the one from the YZ and the YFZ....thanx. Oh yeah, im at aol.com
could you please send me the wiring harness map to [email protected] also. thanks guys.
and would the YZ cdi or rev limiter mount right up or no.
i also heard a rumor that you could just clip i think its the grey wire and that eliminates the rev limiter period. if im wrong please correct me.
The gray wire is a WR trick - there's no gray wire on the YFZ.
The yz cdi fits easily under the hood unplug the yfz & plug in the yz it raises the rev limit to 11000.
Sounds like a good idea in theory as once you've done the cam mod the standard cdi mapping doesn't match.
I was going to go that way but the price was that high I thought I would be better off buying the vortex cdi,which was programed to suit the cam mod.
I would be interested to hear of anyone that tries the yzcdi.
Geoff.
I have both a 04 YZ450F and a YFZ450 so I can try the switch but right now my YFZ is in the shop having the shift drum looked at. So I will have to wait till I get it back.
you guys want a real rev box? two words, Big Gun.Big Gun has a awsome new rev box. I have yet to try it but i have seen the proto type rev box leave stock rev boxs. 3 bike links is alot.A freind of mine Darrell Patton pull a 3 bike link lead on 2 other stock yfzs to pull a hole shot. Did i mention the guys he beat were Kory Ellis and a yamaha test rider. Kory ended up beating him in the race on his new white yfz that was completly stock.
Selector,
Did you ever get that diagram posted anywhere?
.brit
1 - 13 of 13 Posts
