1 - 17 of 17 Posts
Ok i have heard lots of ppl complaining on how their thumbs get real sore and stiffen up when they ride their yfz's. I have also noticed this problem, is there any way to solve it by making the throttle easier to ingage? Post ur thoughts
messing with the spring in the thumb throttle or changing to a honda thumb throttle aint gonna do chit. you have 3 choices ...
1. Get a twist
2. Cut the sping IN THE CARB - this is what is making it stiff
3. sack up :lol
all I know is I ran a FCR40 on my Z400 and with a honda thumb throttle it was much stiffer than the YFZ's. I may give a twisty a try down the road ... has anyone cut the spring in the carb???
Outlaw,
take the spring out of the thumb throttle.
Geoff.
Originally posted by Aussiequadrider@Nov 9 2003, 01:32 AM
Outlaw,
Geoff.
are you REALLY saying that little spring is going to make a difference :uhoh that is all in your head if you think removing the spring from the thumb throttle makes any difference :wtf :eek
here is a test ... pull the throttle cable from the carb and then push the thumb thottle. there is next to no resistence there with the spring or not
then while you have the cable out of the carb, twist the round piece where the cable connects to the carb with your fingers .... now there is where ALL the resistence is. it is the carb spring!!!! ;)
schwendi
sorry mate for suggesting such a stupid idea.
what was I thinking?
Geoff.
so what if you remove the spring in the carb completly will the thumb throttle not return?? or is it totally fine with out the spring in the carb??
its nothing ive done, but no matter what its always going to be kinda stiff IMO. when you push the thumb throttle you are pulling the slide and also actuating the accelerator pump.
here are two pics that show the breakdowns of FCR's. the first is from the YZ450F and the second is from the CRF450 (FCR40)
I cant see the spring on the YZ one .... but I would think you can remove it??? It is #14 on the CRF one
I wouldnt cut down the spring too much as it increases the risk of having it stuck WOT, if you do it let us know how it works out
There's an easy fix, go ride a shee for a year, then jump back on the YFZ and you will kwitcher complaining :evilgrin Honestly though, I have rode the 450 for hours straight and never have I suffered from sore thumb-a-titus. ;)
Exactly my thoughts.
I think the stock lever is too low and causes your thumb to have to stretch.
I was thinking of trying a Cannondale Thumb throttle as they are closer to the bars and seem easier to push.
Stick a 400ex thumb throttle on it. It won't necessarily reduce the stiffness, but the Honda is much more ergonomical and won't wear you out nearly as much.
1 - 17 of 17 Posts
