I have a 2019 yfz couple days back i rode it started and worked perfectly fine then 2 day later it was completely dead i tried bump starting it wouldnt work then i hooked it jumper cables started perfectly fine idled fine but when i through it gear it would bog when giving gas but wouldnt shut off. Check engine light is on. I need help
I have little experience with the fuel injected yfz's but, to me it sounds like your stator or rectifier is having issues. If something with either of these components go wrong, theoretically it could create problems with not providing enough electricity to power the fuel injection components or charging your battery. Be sure to check all electrical connections first, it's better to check the free stuff first. Hopes this helps! :)
