hey guys new member hope you can help
04yfz
cam mod
airbox lid raked
pea shooter removed
165main
45 pilot
gytr needle
anyways i have a small bit of oil blowing out the right side of my cylinder head out of a little hole there any one else have this problem
the head or the cam cover? I have heard of some people that did the cam mod that pinched the gasket when they reinstall the cover and a little bit of oil comes out. Check that.
make sure that your spark plug is in tight. If you are refering to the hole that I think you are, it is a seep hole that drains any water out of the spark plug cavity if it somehow where to get in there. If the plug is loose, it may be puking oil into this cavity also.
The cam cover is not on right. The cam cover also needs to seal itself around the spark plug hole. I would think that the oil is seeping out around the cam cover draining into the spark hole then out of the drain hole. 99% positive that is your problem.
