21 - 37 of 37 Posts
Discussion Starter · #21 ·
Mine did the same thing. Its a lack of fuel getting to the bowl. Check and adjust the carb floats!
Yeap, we replaced the carb from another YFZ, it has the same exhaust but stock CDI - so that's checked already. But we will check the floats. Thanks for your input.
Discussion Starter · #22 ·
Try the jetting suggestions first.
I thought there was a thread about the carb's fuel float not being set right. 9mm is the height. That fixed his issue which sounds like this issue.
Not sure how to test it, but maybe the valves are worn out? It is 3 years old.
Just thinking out loud.
Checked and checked ;/
Thanks for input, at this stage I'm happy to hear any comments. even is some things it might be senseless
we had a bike that kept cutting out a tryed everything we could think of. one night we swaped harnesses with another bike and the cutting out stopped. never did take the harness apart to try to find out why though. just ordered another one
Discussion Starter · #24 ·
Yeap we've done that. Thanks.
What did my jetting suggestion yield?
I'm leaning towards jetting as well especially if you've swapped everything else out. Start with some good base line jetting like you've been given and just mess with one circuit at a time go bigger until it sputters and then back it off to the previous point. When you mean cuts of do you refer to like it just hits a flat spot and won't keep accelerating to the rev limiter? That's a lean condition its starving for fuel
Discussion Starter · #27 ·
Same ;/
However, we took the cover from the air filter and ride without it - and there is an improvement !! The cut of point is at higher revs than before.
We recokon that fitting KN filter would help ? Please let me know what you think guys !
Sure or get the proper jets in there. Are you able to take it to a dyno?
yea mine did that it does it alot worse with the lid on but when you put it on its not as bad....hmmmm maybe higher octane race fuel?
Discussion Starter · #31 ·
You reckon that will help ? Race fuel is not that popular in EU. I'm not even sure where to get it from.
if u got the quad from some one else they maybe put a higher comp piston in with you knowing and had to put in higher octane fuel in there? i dont know just throwin somethin out there
I'm thinking jetting or stator. You may have changed it but Ive bought new ones that were bad. Just sayin. BTW what it TORS
Throttle over ride system. So if your slide in the carb is open but thumb throttle is closed it will kill ignition
Adding the k&n is just changing jetting. Jet to what you have now! Unless you wanted a k&n
Discussion Starter · #36 ·
Fair enough, just thought more AIR would help. Thanks for all the input, guys. I'll play with the jetting and will let you know if that helped or not.
Have you changed the coil and spark plug wire. Mine would rub fine for about 10 minutes or less then start banging out. I have 07yfz450.
21 - 37 of 37 Posts
