I'm hoping you guys can help a fellow Yamaha Sport Quad enthusiast. I'm looking for a 2009+ Yamaha YFZ-450R/X Aluminum Frame. I'm in the process of building the ultimate recreational multipurpose Banshee and I've got a local Off-Road Chassis/Frame and Suspension Fabricator that's agreed to clean up and mod a stock Banshee Frame and convert the front end over to match the 2009 and up YFZR, clean it up and remove unneeded weight, gusset it, and powder coat it hi-gloss candy red.
He needs a YFZ-450R/X Frame on hand to take measurements and get all the specs off of so he can go off it. I don't care if the frame is cracked, bent, or broke as long as it straight enough to get the measurements off of.
I plan on buying some of the Cascade Banshee Stock Frame Mods to incorporate into the new custom hybrid frame. The Hybrid Frame I've designed on a old Auto-CAD PC Program uses stock or aftermarket YFZR A-Arms, Front Shocks, Hubs, Spindles, Tie Rods, Brakes, Steering Stem, Steering Stem Flag, and Aluminum Subframe, with stock or aftermarket Banshee Plastic, Gas Tank, Swingarm, Rear Shock, and Shock Linkage. It also has enough clearance to run a 7" 12V Thinline Radiator Fan.
PLEASE help me out if you can. This quad will be something else with the frame I designed, 10 mil Rotax Power Valve Motor, and everything else I've got go with the combination. The Hybrid Frame is last component that I need to get squared away on.
Thanks guys,
Modded OEM Banshee Long Travel YFZ-450R/X Frame -
Cascade Inovations Banshee Frame Upgrades -
Thanks guys,
