will a 07-08 wiring harness fit on a 04. are all the plugs the same? also will putting that on and a new stator fix the charging problems the 04's have when you remove the headlights? thanks
Yes, as long as you also put on all the extra resistors that the 06 has and the 06 start/stop/starter/headlight switch. The CDI, Stator, small resistor (alm. one that bolts to the frame), startor cyl. and tors components all plug in the same.
