I was putting a new clutch perch on my YFZ and was wondering what do I do About the wires coming out of the stock one and what they do. If anyone can help asap Its greatly appreciated. Thanks
There is only one wire i think. EX80 was telling me i think that you just unplug is from the wiring harness.
You just connect the two wire together and wire tie them somewhere under the plastic and forget about them. Only drawback is it will start without pulling in the clutch after you do it. No big deal though :D
Those wires are the neutral safety switch wires, just snip them splice them together and your good to go. It will then start without the clutch pulled in.
Technically thats the clutch safety switch. The nuetral safety switch is on the transmission :)
you don't have to snip them. just follow them down below the front fender into the black rubber boot that houses them all. both wires are connected to bullet plugs. one male, one femail. disconnect the long pieces and connect the two bullet plugs left over and your done.
