41 - 60 of 977 Posts
Discussion Starter #41
Anyone happen to know if I can just bolt a 14+ slipper in my bike?
I see take offs on ebay for 200 bucks.
Super Moderator
2014 YFZ 450R Trail Machine
*Vortex ecu
*Elka Stage 5 front shocks
*Elka Stage 5 rear shock with modified reservoir bracket
*Walsh link
*Walsh MX a-arms and caster bracket
*Walsh +1 stem
*Walsh stem kit for Precision anti vibe clamps
*Walsh rear brake pedal extension
*OMI greaseable stem clamp
*ODI Rogue lock on grips..silver locks and black grips 130mm length
*Precision Pro Elite Steering Stabilizer
*Precision anti vibe clamps
*Streamline front brake lines oem length with MX a arms!
*Yoshimura RS 2 Pro Titanium with spark arrestor
*FCI with my custom air box and a GYTR Uni air filter
*GYTR hour meter
*GYTR poly engine skid
*Ricochet swing arm skid
*(2) TM DesignWorks magnetic oil drain plugs
*Anti Gravity 8 cell 5000 mah Lipo with quick disconnect connectors for Vortex parasite drain protection.
*DWT G3 Front wheel 10" 4+1 single bead lock
*DWT G3 Rear wheel 9" single bead lock
*Maxxis RAZR 2..Front 21x7-10
*Maxxis RAZR .....Rear 20x10-9
*2013 Cable Holder for AIS delete
*NGK Iridium CR8IEX......spark plug
*Upp poly case saver - need to put it on
Misc:
**Custom electrical cables from wire harness up to grips....I used oem connectors and oem plastic tubing for oem fit and finish!**
*Vinyl tube over front brake line and rear Elka reservoir line
*Custom AIS Delete cap
*My custom rubber bumpers for rear tail light
*My custom oil catcher
*My custom Vortex mount it rocks!
*Front wheel rock guards removed
*3m clear bra...a arms, headlights, plastic, engine cases, frame, tail light, rear shock remote reservoir, etc.
Future Mods:
*2017 plastics oem or SSI stickers
*Rath front bumper
*Rath Cross Country heel guards
*Glann poly belly skid plate
*Glann greaseable swingarm pivot bolt
*Walsh or BrappTech speed sensor block off plate
*Fourwerx seat cover
*Rpm Dominator 2 axle
*Lonestar hubs and nut
Discussion Starter #47
Wow those hoses are shiny!!!! Sexy...lol
20 bucks with the clamps on ebay.
They have the blue liner inside like the high end guys.
I've put these on a lot of bikes, never had an issue on any of them.
Banned
I wouldn't waste the money on paint like that for black. For a special color maybe. But I have always use semi gloss black. Its gonna get scratched or rubbed off sooner or later. I just use cheap generic paint form the hardware store for a fraction of the price. Its simple enough to have a piece of cardboard handy and to touch up the paint on the frame and a arms while the oil drains during my oil changes.
Everyone always compliments how nice my machine looks. I like to mow down trees and create new trails ect. Sometimes its got to be done to keep the ride moving forward.
Discussion Starter #57
Hell yeah! That's exactly how I ride! I bought this thing to have fun. Point me in a direction and get out of my way.
But the white on the frame does kill it for me ill just get cheapo black
used used rustoleum in a spray can and that was 3 yrs ago and you still cant tell where I did the touch up,
Super Moderator
I've got 3 different silver automotive touch up pins @ $14 each and none of them match.....I'm going with the ColorRite silver....I will let you guys know how it matches.
Update: 5-22-17 the paint doesn't match....Go to your local auto body and have them mix you up some.
