Grizzly,
mate take the short wire out of the kill switch and ground it well.
Take the longer wire & splice it into the solid white wire coming out of the cdi.
Good luck, Geoff.
Are you sure it is the white wire ?
I've took a look at the wiring diagram and it is the orange wire that is going from CDI to the ignition coil, not the white. The instruction of the pro design says to wire it on the + wire of the ignition coil.
The white one is coming from the AC Magneto and is going in the CDI.
There are two white wires.
Make sure you use the solid white one.
Have not heard of anyone having problems after doing it this way.
Geoff.
