Do u have the stock carb drain hose on it cause ik that mine didnt do it will the stock drain hose but when it fell off and I put a regular hose on it it will leak when I set it on the grab bar to
^^^^ what he said.but your floats could be set to high you could try to adjust for less fuel in the bowlThats the bowls overflow, when my float pin fell out, it wouldn't shut the fuel intake off allowing the bowl to continue to fill up and it pours out of the overflow if the gas gets to a certain height, I'm sure the same applies to you, your gas isn't overflowing, but when the quad is at an angle, the gas line is over the overflow tube.[/b]
