1 - 10 of 10 Posts
· Registered
First ride on the radius cx today and I am impressed. Install and set up were easy as well as break in. Power delivery is smooth and predictable,definitely feels smoother then the yzf set up I was running. I can pull a gear higher in the tight stuff,lock up the brakes in 4th,no clutch and get right back in it. With being able to run a gear higher it kinda mellows the hard hitting port job on this motor. I will definitely recommend one of these,and honestly wish I would have bit the bullet sooner.
Tire Wheel Fuel tank Vehicle Automotive lighting
· Registered
I prefer the Radius CX because the clutch lever feels alive, and I like to slip the clutch when climbing hills manually. However, the CX will require extra attention for long life and those who don't check free-play will be victims of a pre-mature clutch pack failure. The Z-Start Pro is old technology and continues to be a fan favorite for XC riders. The clutch lever feels dead, but you can still override it when needed. Basically, once the Z-Start Pro is installed properly, it's great.
1 - 10 of 10 Posts
