1 - 1 of 1 Posts
in grams-
RAD
880- Stock radiator w/cap and brass fittings only (brass weighs 77)
1475- Stock full
1562- PWR radiator empty (same as stock)
I couldnt get a full PWR weight, it was to much for the little scale, but the stock radiator holds approx. 1 1/8 pts, the PWR 1 1/2 pts. Not as much of a difference in fluid capacity as I expected, but there is way more cooling surface on the PWR.
So, it looks like I gained about 682g of radiator and 191g of coolant= 873g
OIL
556- Stock empty with drain bolt
882- UM oversize aluminum tank w/bolt empty
The oil tank holds approx 1 qt more oil adding about 838.
So, it looks like an extra 1164g
873+1164=2037
Thats a little more than 4.5 lbs gained.
Removing the battery/starter/fan is supposed to loose how much? 14 lbs?
1 - 1 of 1 Posts
