Hello all!
i have a ton of leaking coming from my water pump case drain hose (not sure what to call it).
so research points to the seals being bad. I have seen a couple people mention a water pump seal sticky and I have search and searched and cannot find it (maybe ive lost my mind).
does anyone have a link for the replacement stick for a carb model bike?
2006 yfz450...
Go to a dealer or a parts fiche.
Get all OEM parts only.
Seals bearing gasket and shaft.
Only thing is to make sure the seals are in the correct direction. Or else itll leak out again just as fast.
It's pretty straight forward and simple once you look at it.
