the spot on the frame is a easy wear spot, and is usually covered up if the frame has been painted or powder coated. but there is another stamp on the engine (assuming its the original cases) on the right side, right above the black plug that the kick starter would go. (right above the rear brake pedal)
They're lieng, its on the inside of your case. Better get taken that thing apart!
