Valve Shiming
906 Views 10 Replies 7 Participants Last post by  davispalmer
hey guys i just checked my valve clearence and they are .004 to tight so can i just order the hotcams shim kit and reshim them?
1 - 11 of 11 Posts
Yes, that is the correct way to do it. Set them to .006 intake and .010 exhaust. :icon_biggrin:
the kit is great to have on hand.... that way you have all the shims that you might need.
we have them in stock... and sell them to members for $68.00 shipped.
Pm me if you need one.
thanks
If you want to buy a shim kit you can but you could also just call your stealership and they will sell them to you individually
QUOTE (2004yfzrider05 @ Mar 23 2009, 12:06 PM) index.php?act=findpost&pid=761036
If you want to buy a shim kit you can but you could also just call your stealership and they will sell them to you individually[/b]
problem is they charge alot for the individual shims.... after a few shim changes, you could have had the whole shim kit to own rather than spend a fortune on individuals at the dealer.
QUOTE (woodwardspecialties @ Mar 23 2009, 02:25 PM) index.php?act=findpost&pid=761108
problem is they charge alot for the individual shims.... after a few shim changes, you could have had the whole shim kit to own rather than spend a fortune on individuals at the dealer.[/b]
Very true.....$68 shipped for the kit is a good price. Setting your valve lash is not plug and play, alot of times you will install what seems to be the right pad, but you will not achieve the right clearance. I recommend buying the whole kit.
yes, buy the whole kit... or find a friend with one like i did. =P
my dealers price is 7 a pop, so assuming i had to change them all, it would have been $35 and thats also assuming i got it right first try.
QUOTE (woodwardspecialties @ Mar 23 2009, 11:25 AM) index.php?act=findpost&pid=761108
very true. $10 a shim at my dealer. im thinkin about buyin the shim kit and be able to do all my frends valves too, and charge them $35 a pop lol
its $60 for a valve set at my dealer
one of my friends had a kit that i borrowed and worked good thanks for all the info guys
can i borrow that kit to?
1 - 11 of 11 Posts
