I just recently bought the stage 3 hot cans for my carb model yfz 450 2012. The sheet that comes with the hotcams say .040 intake and .060 exhaust???? That’s a lot different from stock clearances. Does anyone know if this is right?
Discussion Starter #2
So I read it wrong. Those number are valve to piston clearance.
But my stage 3s are still a good way out of spec from where the stock shims were. Is this normal?
I'LL assume that they are too large. If that's right it's normal. They don't make the lobe taller, the base circle is ground down
