It comes with a new replacement cable. Also you need to determine if you want a fast twist (Vortex model which is more expensive) or the slow twist (CR model) from Motion Pro.
When installing the twist you will need to splice the two leads together (tors wires) that run up to the thumb throttle. I would make the splice and re-connection near the front stem so you can re-solder the tors sensor leads if required.
