That won’t work in fresh snow.
Here’s the add for the led brake light (mine is red): -I had to drill out the mounting holes to have it fit the AC grab bar mounting bracket, not a big deal
just use a step bit and drill.
THIS IS A NEW REPLACEMENT 6 LED TAILIGHT AND BRAKELIGHT FOR THE NEW YAMAHA YFZ 450, EVEN INCLUDES WIRE STRIPPERS, HEAT SHRINK TUBING, ALL FOR AN EASY INSTALLATION. MANUFACTURED IN THE U.S.A. THESE CONSUME LESS POWER THAN STOCK. THEY WITHSTAND VIBRATION ALOT BETTER THAN A STANDARD BULB. THIS IS A SHOW POLISHED, CNC MACHINED PART!!!!! INCLUDES MOUNTING INSTRUCTIONS. SIMPLY WIRES INTO FACTORY HARNESS. OTHER COLORS AVAILABLE - YELLOW, BLUE, GREEN, RED.....JUST SPECIFY YOUR CHOICE. YES YOU READ IT RIGHT IT IS A FUNCTIONAL BRAKE AND RUNNING LIGHT.......DUAL BRIGHTNESS
There email address:
[email protected]
There eBay id is: 1metaltek
If you goto eBay and choose "Search by seller" then enter 1metaltek
This will take you to his current auctions for the ed brake lights, I have a tendency to give allot of detail.
The PEP clutch linkage gives a more even and shorter pull to the clutch lever, it's a little billet aluminum cam shape piece that replaces the stamped metal
Stock piece. It's worth getting.
BTW: For 80 to 90 bucks get the 4Snow that can take the beating on hard sufaces and save the good paddles for sand.
The only true paddles I would run in snow (beacuse I end up on the street allot) are the following:
Skat-Track Terrain Trak-rears
GBC Paddle Master -rears
They can take the beating of hard surfaces without comming apart.
