Tors Question
779 Views 2 Replies 2 Participants Last post by  450speed
I have an 04 and the wiring harness was all cut up to get rid of the headlights and tors. My question is I have a new wiring harness and would like to install to have headlights, but will the quad run if the tors system is not pluged into the harness. The cut off the wires at the throttle and carb.
yes, if you just hook it up with the wires on the carb and on the throttle still spliced, it should work fine. maybe cut off the TORS wires on the new one if you want to save weight =P
not sure what you mean. hook it up?
