did you put new grips on? cause when i put mine on the lever would get stuck on the grip donut once in awhile and i now what you saying when on tight trails it wasnt fun
nah,i've got the oury's cut.this is a internal problem.did you put new grips on? cause when i put mine on the lever would get stuck on the grip donut once in awhile and i now what you saying when on tight trails it wasnt fun[/b]
yea,i cleaned the slide,turned the throttlewheel to w/o,and it will slam shut.Did you clean the slide? Also, what engine setup do you have?[/b]
yea,i was just seeing if i could get alittle better starting,maybe i would benefit from the fuel with more consistnant jetting.i'm gonna go back to reg.93 though.this started with the fuel,i know it makes no sense.You don't need to run race fuel with that setup. I doubt that's your problem though.[/b]
i plan to keep playing with the jetting,but i don't think it is the jetting.it was operating fine,and the warmer the weather gets,the worse it seems to be.but it has never been a prob to recently.I had the same problem and went one size up on the pilot jet and the problem went away[/b]
hey,clueboy,get one and read the thread from the top :strokin:they usually keep there revs like that when there too rich. Change the pilot.
And one suggestion, dont be so hard headed about stuff. Be open minded or your never gunna find out whats wrong cuz you dont beleive anybody. Be willing to try anything these guys say on here, cuz i bet that most of them know more then you lol[/b]
i did. And you aint gunna get any answer with that kind of attitude. Were givin you suggestions and your not listening, thats all im saying. Anybody can be tough behind a computer screen.hey,clueboy,get one and read the thread from the top :strokin:[/b]
i just had the head off and went through it,6 hrs on the motor since.you've checked your valves? one could be hanging open.. also try a pilot change like suggested..
I use to have that problem and it was a bent valve. :bawling:[/b]
check the intake boots also.. could have a hole in onei just had the head off and went through it,6 hrs on the motor since.
i have went from 45-50 pilot with no change.
i'm gonna replace the clamps on the intake,possibly a leak.[/b]
yea,the intakeboot could be the prob.i'm gonna try new clamps also,thinking they maybe alittle tweeked from on and off so many times.check the intake boots also.. could have a hole in one[/b]
i guess you are talking about the screw that goes into the throttlewheel shaft,correct?if so,it is tight.also make sure the screw that holds the slide up and down mechanism (no idea what its called) Just make sure it is tight, because mine came loose and it would just bounce off the wall because the slide was bouncing up and down...[/b]
