Ok, so here's the deal...
I bought three YFZ's this weekend... All of them non runners. Busy stripping the motors and deciding what to do and how to do it.
Chassis :
First chassis is a black and red '07 Limited edition chassis in very good condition. Hauser steering stem, aftermarket nerf bars, lone star axle, wheelie bar, bumper and exhaust. This is the bike I'm gonna build up for myself.
Second chassis is apparently an '06. Not much extras except for pro circuit pipe and red bull sticker kit. Gonna build this one up and sell off.
Third chassis is a bare frame with front suspension and PEP rear shock. Do have a set of plastics. Also has a Lonestar swing arm and axle. Will either sell off as spares or try and build a hybrid/std bike.
Motors :
First chassis' motor is disassembled and doesn't look like there's much wrong with it. Has a hotrods conrod and ported head, and a gold coloured GYTR clutch.
Second chassis' motor we took appart yesterday. To my dismay it dropped 2 valved, broke the piston, bent the rod and obviosly stuffed the crank. Oh and tore through the barrel...
Third chassis' motor is totally stripped and in boxes.
Fourth motor... Well I got half a fourth motor in between all the spares
As well as an extra crank, conrod and about 3 pistons. One is a WISECO one is standadrd and the other seems to have a higher compression than standard.
So, I don't know much about these bikes and I hope I could pick your brains over the coming week or two.
The goal : To build a reliable and powerfull engine for Chassis 1.
1. Mainly (for now) I need to know if there is any play allowed on a crank/conrod (assembled). Three of the cranks I have, have sideways play on the conrod but no up & down play. Maybe about 1mm or so.
2. Regarding the heads, is flowed heads with bigger valves an option or is a standard head fine?
3. I read somewhere about the WR's crank that could fit. Is there any other parts from other motors that will fit the YFZ?
4. So after '06 the upgraded the motors with the oil squirter. Is there a how to on this? Or is it machine shop only?
Thnaks in advance guys!! :clap
Chassis :
Motors :
