Does anyone happen to have the specifications for the springs used on the YFZ450? The free standing (no-load) height, inside diameter, and spring rates are what I'm looking for.
I'm tolld the spring height might be obtained if you back the preload adjusters all the way out until the spring is loose. Otherwise, the spring has to be removed from the damper to be measured.
Thanks in advance!
I thought there was a section in the shop manual that had spring measurements... might want to check the one posted on line
