on the stock shocks... bottom of the piggybacks, there is an air valve... what is the function of valve??? to fill with air??? to let excess air out / bled???
when i came back from my last trip, i notice a "cluncking sound" just before the tire comes off the ground when i pick it up... like if there is a end play (about .125") at the bottom of the shock...
do i need to put air in my shock? or ????
please help 8|
That fitting is where you charge the shock with NITROGEN only.
You should only need to do that, if you rebuild your shocks, or have a leaking seal.
a little slop right at the top of the shock travel probably isn't a big deal, but I would check for a loose shock bolt.
