Would a +2 steering stem be to tall for the stock cables? Seems like most of you are going with the +1.
+2 height and +1 forward. stock cables. has to be re routed though. plus i used 30" bars w/cr high bend barsYes the would be too short so i would go with +2 Stainless ones like Galfers.
This will allow enough cable and greatly improve brakeing.
How bout a side shot of your steering, from the plastic up. Nice setup-me likey.+2 height and +1 forward. stock cables. has to be re routed though. plus i used 30" bars w/cr high bend bars
I would have disagree. I went with LSR +1 and Tag 2 med bend and it was higher than stock. It snapped the clutch cable.Originally posted by RPyfz450@Jan 19 2004, 01:48 PM
The stock bars have such a high rise to them, just about any aftermarket handlebar you buy will likely come out lower with a +1 stem. I just added the tallest tapered bars I could find from Renthal. Even with aftermarket bar clamps that raised 7/8", I think I'm only about 0.25" taller than stock. If I buy a steering stem, it will definitely be +2" and then I'll have the option of adding any bend bars I can find, not just the extra tall ones. The bars I bought are taller than all the "hi-bend" bars out there.
