Yup.....I took the bolts out of the neck holding it above the radiator. I removed the large carter pin, and nut from the bottom, and it still won't budge. I looked up inside to see if there was a snap ring, but I couldn't see one. SO what's the trick? Is it threaded in? pressed in? My column still feels like it has good movement in it, so it's not binded anywhere.
What's the deallio?
Thanks.
What's the deallio?
Thanks.
