I would make sure the throttle cable is allowing the slide to go down all the way, idle needs to be higher then you'd expect at 1850rpm.... then check the pilot jet and fuel screw. 45-48 is the normal range for the pilot jet, and the fuel screw is normally 1.5 - 2 full turns out from fully closed.
