So Facebook says the problem is probably the one way bearing. What's everyone here think? Other then the bearing what should I order? I was going to order the case gasket and a flywheel puller. The shifter is broke in the transmission but I'd like to tackle one problem at a time. I was going to upload a video but apparently I have a file extension that's not allowed?
Teeth on the starter or starter gear are gone. The one way bearing could also be it. I would open it up and see if the start gear is rotating before ordering. If it is spinning its the one way bearing if not it's the starter itself
I opened up thay small cover. The gear on the starter itself seems fine. I don't know how I'd test the bigger gear that's under that small cover. I need to actually tear the entire thing apart I just haven't had time unfortunately.
