You could shave off .020" and that would bring the piston at tdc .028" squish... not sure on the compression you'd have after that, or if the piston valve pockets are deep enough for those cams. All of this will also retard both cams as well.
Can you just use a thinner base gasket?
The side skirt coating is no big deal, and it being slightly worn off does not mean the piston needs to be replaced.
The 13.5 CP may change the squish if it uses a slightly relocated wrist pin. I however do not know the details on it.
