many people keep making the comments that the kicker will not clear.... but they do!
on the 1st design from sparks the pipe stayed out a bit... and the kicker would hit it....
now on the newest ones that i have got in stock, the bend is slightly different which should allow more room giving the kicker room to clear....
and as far as cracking, on the latest sparks pipes i have recieved, the metal they are now using is much stronger. the vibration was causing the thinner pipe to crack where it enters the silencer. now the stronger pipes are supposed to hold up much better.
although... even on the older ones, sparks is upgrading it to the heavier metal, and recoating them at no charge if they crack. the downtime hurts... but sparks is standing behind their product 100%
