what are your guys opinion on spark plugs... regular ngk? pulse plug? other?
thanks!
Discussion Starter · #2 ·
ive also heard of something like iridium i think it was
yeah but is there anything better?
I've had good luck with the Iridium Spark plugs from NGK. They seem to last a little bit longer than the regular ones. It should be CR8EIX is the model of the spark plug. The IX usually indicates that it's an iridium spark plug.
Ive been running the NGK resistor plug CR8E for the last 4 years in my YFZ and have had no problems wutsoever.
Is there any benefits from running the NGK Iridium plug? ive never tried one.
I have worked at GM and big truck dealerships... To me a spark plug is a spark plug.. I put what it says to put in it and have not had any issues. I dont think you will notice any gains from a different spark plug. Only if you use the wrong plug...
