any suggestions on a aftermarket flywheel weight/ and how much of a job is it to change one. i just bought mine 2 days ago and i race in the wnyoa harescramble series(super tight tracks) and the gncc's. any help would be great.Get a weight for the flywheel or try an aftermarket one for the really tight stuff.
Trailtech is supposed to be making a second run of these (flywheel). You'll have to get a flywheel puller also, or have a dealer do. I'd get the puller and the manual for the YFZ and do it myself. Then you have the puller and it'll probably be a little cheaper. My mechanic is currently working on some weights for the stock one but it'll be a couple of months probably. Also, make sure your idle is at or a little above the stock setting, which I believe is 1700 rpm's. I've got mine around 1800 and it helps. Get ready to work the clutch in the tight stuff! O yeah, what is wynoa? We've got a race tommorrow and I can't sleep. Just got AXIS all the way around! The rear one is soooooooo plush!! It definitely lowers the ride height.Originally posted by bigdaddy@Nov 14 2003, 04:48 PM
btw,thanks for the heads up on the raptor stem. i have a burgard =1 stem on my raptor i think i'll try.![]()
wnyoa series web site. look at the results. top 25 quad riders. i am 6th in the overall.what is wynoa?
good luck tomarrow. make sure you post your results. what series is it?We've got a race tommorrow and I can't sleep. Just got AXIS all the way around! The rear one is soooooooo plush!! It definitely lowers the ride height.
Asher,Originally posted by Asher@Nov 16 2003, 08:51 AM
learning the clutch is cheaper and no weight added :lol i dont think i need the weights now that i know what they are for, and i dont race in the woods anyways i was just curious as to what it was for and what the plus was, thanks
Thanks for the luck. I finished second in the ATV Sport Pro class. I got a bad start and was 8th off the line, zig zaged through a field and went in the woods 3rd. My buddy got the holeshot on a 86' 250R and kinda' checked out. It was bad dusty and the guy in front of me was stirring up so much dust I ran off the course four times on the first lap. Finally past him 1/2 way through the first lap but couldn't guy my buddy. He won on the holeshot. We had the same interval every lap. It's just a local series at Durhamtown Plantation (www.durhamtown.com) I finished 5th for the series and only raced half of the races! I love this Quad! What part of NY do you live in?Originally posted by bigdaddy@Nov 15 2003, 04:23 PM
:stupid , but bout the +3 arms....... i thought u can only get +2's on a YFZ..... wouldnt +3's put it over 50?Originally posted by nacsracer27@Nov 15 2003, 06:02 AM
MX= Klaws all the way around, TCS SCS shocks, +3 a-arms, 4:1 offset fronts, rear beads, RPM axle
