what’s up guys! I picked up an 05 about 2 weeks ago from a guy who had said the clutch basket he had in it before had exploded it was an aftermarket wiseco basket.. anyways the case was good so I put all new oem stuff back in and put it together but couldn’t get it to start so I checked the usual.. 1. Carb fully rebuilt 2. Spark put new plug and checked it for spark. Then went on to check timing and when I set the motor to top dead center I noticed the dots on the gears lined up with the case but on the inside and the lobes were facing each other, so I took it all out and setup so they matched up with the outside of the gear and the lobes facing away from each other.. now I’m having an issue where the tires will only spin in reverse.. what the f is going on…
