Right Tire Is Angled
1688 Views 11 Replies 7 Participants Last post by  scottevil
my right tire is angled on my yfz.i bought it like that i was just woundering how u adjust it.im not sure but do i adjust it by the tie rod? thanks
is the tire angle in on the front or the top? if you look at it from behing the tire and the front of it is Toed in "angled"
then yeah you adjust with the tie rod.
QUOTE (Derek_c23 @ Mar 21 2009, 06:40 PM) index.php?act=findpost&pid=760504
then yeah you adjust with the tie rod.[/b]
its the top of the tire
if its the top then thats your camber adjustment. Do you have stock or aftermarket a arms? If there stock you can't adjust it. If its aftermarker remove the upper balljoint and screw it in or out to adjust the camber..
QUOTE (Danny T @ Mar 23 2009, 10:50 AM) index.php?act=findpost&pid=761095
if its the top then thats your camber adjustment. Do you have stock or aftermarket a arms? If there stock you can't adjust it. If its aftermarker remove the upper balljoint and screw it in or out to adjust the camber..[/b]
stock, whys it like that though my left tire isnt like that
It could be possible that the upper ball joint has an excessive amount of play, or the uper arm is bent down ward. I would inspec that upper arm very carfull to check for bends, play in any of the joints, and inspec the spindle its self alos to make sure that didn't get tweaked in any way shape or form.
post some pictures so we can see what your talking about.
Mine is like this too on stock arms but im blaming mine on a few wrecks :icon_eek:
Did you buy new or used?
QUOTE (TopGunYFZ450 @ Mar 24 2009, 11:06 AM) index.php?act=findpost&pid=761478
Did you buy new or used?[/b]
i dont have any pics right now ill upload some later
and i bought it used but it had only 2 or 3 hours on it, the guy bought it for his daughter and it was to much for her so it was pretty much new
my left tire is angled pretty good because my top a-arm is bent in a little
QUOTE (zaathur151 @ Mar 24 2009, 06:46 PM) index.php?act=findpost&pid=761801
my left tire is angled pretty good because my top a-arm is bent in a little[/b]
my buddy bought a new 400ex and his right tire was angled like that from the factory!, he kept it but you can bet i woulda taken it back to the dealership.
you can also measure the top arms and bottom arms to make sure they are the same length, it could be a manufacturing flaw
I had the same thing on mine. Look at the lower a-arm. They are a gulwing design and I hit mine on a large rock and straightened it essentially making the lower arm longer...
