does anyone know if there is a way 2 adjust the rev limiter without having 2 buy a new 1?
please put your input
not neccesarily. most quads, unless setup specifically for it, lose power as the rpm's rise. up'ing hte rev limiter will improve top speed though.Originally posted by WickedWhite450@Feb 10 2004, 10:07 PM
No its not bad for the motor. it allows all access to the bikes power through the broad power band by letting the bike rev higher. More RPMs more POWER
you have to get a new cdi box... alba sells one that bumps up your rev limit by 1000 rpms..for 199.00
THere is no "Grey Wire" mod on the quadOriginally posted by DigitMXTracks@Feb 27 2004, 06:15 AM
i have heard rumors about some of the dirtbike guys with the yz450f that they can simply clip a "grey" wire and the rev limit will be eliminated so you can rev to the moon. but i dont know how this will effect the ignition curve or if it can simply be done with the quad. is this possible or is it even a good idea?
No.Originally posted by bunkerking217@Feb 27 2004, 09:00 AM
can the stock box be drilled?
