Rev Box?
733 Views 11 Replies 3 Participants Last post by  YFZER359
i think that my gears are a small and hit the rev limiter extreamly fast. should i get a aftermarket rev box or is there a way to mess with the gearing? thanks for the help!
Change your gearing ratio. Rev box will only bring you trouble.
yea what sidewinder siad.
Rev Boxes just raise the limeter, you usually dont use that extra 1000RPM anyways, pretty pointless.
QUOTE (Sidewinder @ Mar 7 2009, 11:40 PM) index.php?act=findpost&pid=755092
Change your gearing ratio. Rev box will only bring you trouble.[/b]
how do you change the gearing ratio?
Adding teeth to the front sprocket or losing them from the rear would probably fix your problem.
adding 1 tooth in the front is like dropping 3 teeth in the back. But a 36 tooth rear sprocket is the smallest you can put on.
QUOTE (YFZER359 @ Mar 7 2009, 10:46 PM) index.php?act=findpost&pid=755098
adding 1 tooth in the front is like dropping 3 teeth in the back. But a 36 tooth rear sprocket is the smallest you can put on.[/b]
kinda tight on money is ther any other way to do it?
a sprocket is like 10 bucks lol its really that tight?
the fronts are like $10-20 and thats the one i suggest putting on. Do you know your ratio? Have you changed it at all?
QUOTE (YFZER359 @ Mar 7 2009, 11:50 PM) index.php?act=findpost&pid=755100
the fronts are like $10-20 and thats the one i suggest putting on. Do you know your ratio? Have you changed it at all?[/b]
wow thats alot cheaper than i expected lol, no i havent touched it
did you buy the machine used?
QUOTE (YFZER359 @ Mar 7 2009, 11:53 PM) index.php?act=findpost&pid=755102
did you buy the machine used?[/b]
yes but the guy i bought it from was scared to touch the engin at all exept for pipe and thats it
oh, it should be stock gearing then.
Check what size sprockets you have and report back.
